During a recent extension I laid in 6mmsq 3 core swa from the CU under the stairs to the future location of my garage and 2.5mmsq 3 core to the expected shed location dug to required depth with tape etc. to ensure I was covered for supply
Unfortunately we decided to switch the two around. Obviously the shed should still be 'just about' ok if I decide to get that done.. But what are my options in the garage.
The 2.5 swa to the garage is under the floor for 9m, by my calculations of voltage drop it just about scrapes in at being okay for 22A, could I therefore have a new CU with 16/6A mcbs for ring/lights running off this cable? I am not expecting to use serious power tools in the garage but am concerned this would be easy to trip
If not, the garage is attached and there are sockets in the lounge where the ring could in theory be extended in to the garage, the SWA could then just be used for the light circuit..?
I have a last resort option that I would rather avoid due to cost and appearance - it may be possible to run a cable up into the loft from the CU then back down the outside of the house into the garage (possibly entering through soffit), total length of run at least 15m - I am assuming the cable down the outside of the house would ideally be SWA but could probably be terminated in the loft and connected to T+E?
any thoughts?
best regards
Trevor
any thoughts?
best regards
Trevor
