hI,
I have just replaced my old MK RCD only consumer unit with a larger MK split load.
This now allows me to have a separate 'normal' feed to the outside , which is currently split via a junction box , to the garage and garden shed which are in the opposite directions. The garage contains freezer and flourescent light. and feeds one high energy outside sensor light plus several other bulkheads using low energy bulbs.
Can I use the old RCD unit for the garage and what rating MCB should I use to feed it, currently 16A, whereas the old units RCD switch is 80A.
Or, ( obviously but costly )is it best to get a proper garage unit ?
