garage supply
23 Nov 2011
What supply can i use for a rcd garage fuse unit. at the moment there is a old type fuse bs3036, this is supplied by 2.5 m cable then 2 fuses are run of that. can i do the same by using the original 2.5 m cable into the rcd and the connect up the light/socket radial circuit on b6 and b16 mcb.
