Garden lights.... is this safe ?
Interesting replies, conflict of opinion !
I'm still interested in the Armadillo, even though the concern is then aimed towards the rest of the 'fixed/permanent' lights. Could FP200 be attached via glands the the junction box supplied with the Armadillo ? Reading posts on this forum, FP200 seems favoured by some of you for exterior use over artic. It seems you cant always attach SWA to lights anyway, so if they are not designed to use SWA, FP200 or artic should be fine !
Just to point out, I intend to run the cables attached to underside of decking or along walls using conduit if necessary, at no point will it be loose over concrete or soil.
