P
primarycause
Hi All. Complete newbie here, this is my first post. With forum members' help and advice I intend to document the build of my garden office on this thread. Hopefully this will provide forum visitors with information for future projects.
I have undertaken to build a garden office approximately 4m X 4m with timber construction (cedar cladding/tyvek or similar/ OSB/ kingspan/4X2/ foil backed PB) . It's more than a metre from any boundary and I intend it to have a flat DPM roof at just less than 2.5m high.
I have cleared the area for the base and given that it's on sloping ground, have built a small retaining fence. The ground is roughly levelled and I'm down to undisturbed clay:
View media item 69233
I have a delivery of 4 tons of MOT type 1 and 1 ton of sand arriving tomorrow and I will be hiring a whacker plate this weekend. I will lay 4in of sub base, compact, then blind it, add 1200 Gauge DPM and will pour a 6" solid slab for the foundation. I'm also considering throwing in some steel mesh as well for a belt-and-braces approach.
I have a couple of questions:
1) Is the steel mesh overkill or a necessity?
2) Can I set anchor bolts in the slab, lay DPM and attach my floor plates using the anchor bolts and do a floating insulated floor? Or would it be better to lay bearers, then joists, insulation, OSB floor and then build the wall plates off the OSB floor and joists?? (I'm specifically worried about vermin ingress and insulation/floor damage with the bearer method).
Apologies if I've given way too much info/not enough or have used bad terminology, as stated earlier- I'm a complete amateur. Any help would be massively appreciated.
