That will be the one which you did NOT quote, will it, thus making it far from obvious that "I did enough research to ensure I needed neither planning nor Building regs" only applied to dimensions and location?Thanks also for establishing that I did respond appropriately to beefpotnoodle's questions in respect of building dimensions and their interaction with the relevant regulations.
Just goes to show how wrong you can be.Although, I must add that having seen your "helpful" posts in the past, I'm pretty sure that your post contained no real altruistic intent in respect of educating myself or any other visitors to this forum.
Just goes to show how wrong you can be.I think that in all probability, your post was most likely a thinly veiled (albeit transparent) attempt to belittle someone who you (wrongly) thought you knew better than.
You said things about needing, or not needing, Building Regulations approval based on the size of the building.
I pointed out that there was also electrical work to consider.
The words that I wrote were
"As you will if it contains a consumer unit or any new electrical circuits" and "So no notifiable electrical work then?".
That you could see those words and with even a scrap of rationality decide that I was trying to disparage you beggars belief.
Has it helped educate you in not being such a **** as to look at words written down, deciding that there are other words there of your own invention, and then blaming the person who did not write the imaginary words because you don't like what you imagined?I hope that this exchange has equally been a learning experience for you and has helped to educate you in the benefits of:
1) Being more informed, and;
2) Reading threads more thoroughly
If you think I've been embarrassed by an idiot like you, with your febrile inventions, then you can add being deluded to your list of intellectual shortcomings.Heeding both lessons above will ensure that you avoid blundering in and should help limit your future potential for embarassing yourself on a public forum.
The only opinion I vouchsafed was regarding the wording of the Building Regulations. Everything else was a fact. Are we to take it that you don't agree about the wording of the regulations?However, even badly informed opinions contribute to the debate
