Hi all,
I want to install a PIR style light outside overlooking my garden, I'm in the midst of kitchen renovation and so have the opportunity to put in a nice neat switch in the kitchen that allows me to turn it on and off etc.
My questions are:
- If I were to use a 500watt/1000watt PIR, could this be a spur from my downstairs radial light circuit or would it have to be mains - my CU is RCD protected?
- Based on the above, what weight cable would I run to it? Would it have to be specialised cable as it'll also pass outside.
- Where the cable exits outside through a hole that I'll drill through the wall, what sort of shielding is required where the cable will run up the wall to the light?
Many thanks!
My questions are:
Many thanks!
