Note: If you have questions, please start a thread in "Building" or other sections. "Your Projects" is not for questions.
Hi;
I have finally started to build my garden workshop / shed and thought I would start a project thread to show what I am doing and get advice along the way.
The shed will be a part block / part wood frame construction with probably a fibreglass roof. The blocks will be about 4 layers high with a timber frame on top clad with T&G on the outside and possibly OSB or Ply on the inside to accommodate for fitting some celotex insulation.
Here is the original shed - not even tall enough to walk in without catching your head on something!!
First I dismantled the wooden sides, cut the roof pins holding on the roof and removed the corrugated asbestos roof sheets. Removed the rest of the timber frame - apart from one piece of what looks like a telegraph pole.
I then prepped the top of the rear wall by cutting of the concrete curved weather facia to facilitate extending the top two courses to accommodate the new roof flashings. Also dug out the existing lead flashings.
Also in the pic above I cleaned up the crack in the rear wall ready for a repair and removed the cement pattern blocks where I will fit probably fit a window.
All of the old wood has gone to the recycling centre and I just need to get rid of the 1 1/2 sheets of Corrugated Asbestos.
The new workshop will be higher (less than the allowed 2.5m) so I can easily walk into and work in it. The floor area is triangular and tapers from the left to the right as you look at it in the pics but I will extend it as far as is practicable and the remaining outside area to right of the shed will be a covered log / bin store.
As I mentioned earlier, the roof of the shed will probably be fibre glass but I either need to continue this to the right for the log store or maybe use a separate pitched lean to roof for the logs using tiles of felt? This would mean trying to some how join the two to prevent a dripping area between the lean to and the workshop?
Initially I was going to have a pitched tiled roof from rear to the front but this would have needed a gutter which would encroach on the path. So to help maintain head room my intention is to have a flat roof. The flat roof will have a water run off on the left maybe into a small water butt?
Questions:
1. Do I need to lay a first course of blocks on their sides?
2. Do I need a DPC?
3. Do I need any sort of membrane in the concrete floor construction?
4. Do I build the corners up first?
5. On a wall of 4 blocks high do I need any pillars?
6. For the door what gap should I leave?
7. When laying the wall blocks what spacing between the breeze blocks?
8. What would anyone recommend for a door and windows? Needs to be low cost but long lasting?
9. What depth do I need to consider for the flat roof? I need this to work out measurements from where I intend the flashings to be installed between the top two courses of blocks (those painted cream in the pic above). This will help me to work out how far down I need to go to maintain head room.
More to follow...........
Questions:
2. Do I need a DPC?
