We recently had BG out to replace a filling loop on our Worcester electronic 9.4. While the engineer was here, he tinkered with the boiler itself, and ever since, every time I turn a COLD tap OFF, the resulting increase in pressure causes the diverter valve (brand new last year) to actuate as though someone's turned on a hot tap. This is what the boiler sounds like anyway. I understand how this works - the increase in pressure when the cold is turned off forces water through the diverter valve/heat exchanger/flow switch into the hot side, forcing the boiler to think the hot water is on. Our taps are quarter-turn, so the increase in pressure is sudden.
Is there anything I can do? Or should I get BG out to fix this? Will it harm the boiler?
TIA
TIA
