I have a Potterton Kingfisher 2 boiler. This morning it has started behaving strangely, the boiler appears to be letting a significant amount of gas build up before then igniting the gas. This has the consequence of causing what sounds like a big "whoooomf", which scares the cat who likes to sleep near the boiler in its warmth.
I've checked and the pilot light is fine and so it doesn't particulary worry me but it's obviously not performing to spec and I wondered if this is something that I can fix or do I need to get somebody out to look at it?
The system as a whole is functioning OK, we've always had a minor issue with it that I presume is unrelated but I'll describe in case it isn't. We have a twin valve system that permits the CH and HW to be heated independently, most of the time it's set for the CH and HW to both come on in the morning and the evening. However, in the winter the CH is set to come on during the day as well, just on its own. When the CH is set to come on on its own then the whole system doesn't perform as well:
The boiler switches on to heat water but then switches off after about 5 minutes even though the CH room stat hasn't reached the required temperature. I can still hear the pump pumping whilst the boiler isn't heating and then about five minutes later the boiler will switch on again. However, a reasonable room temperature is maintained and we've generally accepted this because ... it is noticeable that if the HW is switched on during the day in the winter then the above problem doesn't occur, hence if the house is particularly cold during the day in the winter then we manually flick the switch on the timer for HW.
Any help appreciation, thanks.
