The system is 10 years old and always suffered air in the system - initially bleeding 1 radiator upstairs weekly and air would come out of the radiator for a couple of seconds. Over the years this has increased to several radiators - probably down to corrosion in the system. Now suffering kettling in the system above the pump. Put some sentinel x400 in the system and this has got rid of the kettling although I think must have some large deposits in the pipework above the pump as a magnet sticks to the pipework. An H diagram represents the piping arrangement. The 25mm pipe joining the 2 legs is 4" long. Top left leg 25mm air vent Bottom left leg 25mm from boiler Top right 15mm cold water and bottom right 25mm to pump. Sediment is in the middle leg plus the leg to the pump. Is this configuration OK. My next door neighbour has the same system as myself but the cold inlet is 2" to the left and they do not have any air problems. Could my design be the problem ?
