- Joined
- 30 Oct 2006
- Messages
- 6,751
- Reaction score
- 381
- Country
i see......so we have moved on from the previous points which you have ignored to completely new ones then.
no. a tightness test is not done to "find" anything. a tightness test is performed to prove or disprove that an installation is sound within a certain set of parameters. if it fails any of those, then i can go and "find" the leak using whatever method i deem suitable. (be it soapy or match clf)
whether or not those parameters are correct was never clearly brought up until now.
whether or not im am familiar with 12bar is not relevant. the statement itself is confusing anyway as anyone who knows what 1 bar is will know that 12bar is 12 times 1bar.
ive never fallen foul of this phenomenon before. perhaps my judicious use of flux on my soldered joints has thus far prevented the issue arising. ill be sure to look out for it in the future.
im not sure what this goes to show other than proving that you are the foulmouthed blowhard you have shown yourself to be in the past. i know more than enough to do my job safely and within the scope of the regulations. anything i dont know i would be sure to check up on.
So you obviously think a 20 mbar tightness test will find a leak in a compression fitting.
12 bar (something you might not be too familiar with)
may not even find a leak in a fluxed up joint. A few weeks down the line and the joint drys and hey presto a gas leak.
Shows how much you know.
Who,s talking out of their a**e now ???
