H guys, this is my first post on here and would be grateful for some advice. I will try and give as much detail as I think relevant. We want to upgrade our boiler and have run into a few issues that has confused us.
We currently have a Worcester Highflow 3.5 Open Flue floor standing boiler that was installed in 1993 in a cupboard in the centre of the house upstairs. The gas supply pipe that feeds the boiler is approx 16m in length, which runs from the meter at the front of the house to the back of the house (goes right through the centre of the house and so no access), up to the first floor then to the cupboard. I have calculated that there will be 6 90 degree bends. The supply pipe is 22mm throughout. We have a 4 bedroom semi-detached house, with one bathroom and a shower room. We have no other gas appliances in the house.
We want to upgrade to another Worcester boiler but need to locate the new one in the same location. British gas have given us a quotation and have recommended us to replace with the Worcester Greenstar 440CDi, while another Gas-safe installer has said we cannot go above the Greenstar 34 CDi as the gas supply pipe run is too long for the other boilers. We are now wondering why British Gas did not raise this as an issue. We were hoping to go for the 38 or 42 CDi as these have a higher DHW flow rate similar to our existing boiler. The Worcester-Bosch website also states that for a 4 to 5 bedroom house with 1 bathroom and 1 shower room, they recommend the 38CDi or 42CDi.
Can anyone please advise us as to whether you think the 34CDi would be adequate, or whether we could indeed go with the 38 or 42CDi? Is the 22mm gas pipe sufficient or not?
Any help appreciated. Thanks, Dave
