Hi all,
I'm just designing our new kitchen and I have a question ...
The gas hob I like is 70cm wide (5 burner) and the canopy which comes in the range of units the wife has chosen is 80cm wide and will house a 60cm extractor.
Assuming that the wall units either side of the canopy are fitted at or above the minimum height of 46cm from the worktop, will there be enough clearance between the hob and the wall units?
The kitchen on display at the outlet had a 4 burner hob which has loads of clearance.
I'm guessing it'll be okay as I've seen many 60cm hobs sat under 60cm canopies but thought I'd check with the experts.
