My new kitchen design looks like this:
As you can see, there is a tall larder unit close to the left of the gas hob. In the design above, the distance is 170mm from the left of the hob to the larder unit. The hob installation instructions state that the minimum distance should be 150mm, so it seems like I should be ok.
However, I have read elsewhere that the minimum distance between the gas hob and a flammable surface (ie the larder unit) needs to be 300mm, as stipulated by some official UK building codes. Is this true? I've not been able to find it in any official documents. Are there any GasSafe people here who can answer for sure? I've read on other threads that some UK regulations state 300mm but these are overridden by the manufactures instructions. I've also read contradictory opinions stating that the minimum distance should be the greater of the 300mm and the manufacturer's stated minimum.
Anyone able to enlighten me? If you are a GasSafe fitter, would you fit a gas hob as above?
