- Joined
- 27 Jun 2020
- Messages
- 35
- Reaction score
- 0
- Country
Evening all,
Just had a gas hob fitted and the plumber did a gas test after and said there was a leak because of how fast it dropped on the machine he used, used some spray and found it bubbling on a joint, he tightened it up and did another test.
The second test started at 21.05 and dropped through the two 30 second tests to 20.67ish, with it dropping does this mean there is still a gas leak, he said that the drop was nothing and it can have a drop of 6 bar meaning it could technically drop to 15 over a 2 minute test?
My only problem is, if this is correct and it can drop would i not smell it and would it not cause the gas to collect and set fire/explode when lighting the hob/lighter etc?
Thanks in advance.
Thanks in advance.
