The gas inlet working pressure in the Vaillant EcoTec plus 630 System Boiler is 16.5 mbar. The recommended pressure for this boiler is in the range 17 – 25 mbar.
The gas flow rate is 3.2 cubic metres per hr for natural gas. The recommended rate in cubic metres per hr is:
Nominal – 3.24
+5% - 3.40
-10% - 2.91
I am told that the output pressure from the gas meter is set at its maximum.
If the working pressure is very slightly less than the recommended rate, what are the implications? If I need to increase the gas pressure, what do I need to do?
Is the gas flow rate ok, noting the above readings?
Anything else that I should consider?
Many thanks for your help.
Nominal – 3.24
+5% - 3.40
-10% - 2.91
