Hi
Just had plumber around to give us a quote for connecting up my gas hob.
He informed me he couldn't do the job because my gas main from the meter to the boiler is undersized at 15mm so if he connected up the hob this would reduce the pressure at the boiler further.
The measurement at the boiler was 19mb and the boiler type is a myson wm30/40. The max pressure i can see on the serial plate is 13mb.
The quote was £546.25 +vat to provide a new 22mm and 15mm gas main to be run under floor void to feed one new gas hob and one existing central heating boiler.
This is well over my budget so told him to forget it as i will get an electric hob instead. He then said I might as well get it done as next year the home info pack comes and the currnt gasmain isn't up to current standard
Requireing me to sort it out before i can sell.
Is this right, is the pipe to small to run a hob and the boiler?
Cheers
Cheers
