Dear all,
I had a search on the forum and couldnt quite find what i was looking for.
Basically having a new installation done and the corgi man said i would need a 28mm gas pipe, however, the original was only 15. i was going to upgrade to 22mm which i have a load left over from the CH but dont really want to splash out on a load of 28
Does any of you know how to calculate the exact requirements for the piping.
basically the arrangement will be meter tee to boiler carry on then another t, one going to the cooker and then one to the fire,
I guess you need to know the energy output of each appliance, and the length of the run, number of elbows in the installation, and the maximum capacity of the meter. But i have had a look on line for a calculator but cant find one.
the boiler is 30 kw, the fire is 2.3kw heat input and the cooker dont know but the mrs wants a 6 burner range job..
the length of the total run is about 10-15 meters.
thanks in advance
adrian
thanks in advance
adrian
