undersized gas pipe shock!
  • Thread starter Thread starter gastastic
  • Start date Start date
Status
Not open for further replies.
You are best staying there then to be fair, out of interest, in the past year, how many boilers/unvented/vented systems have you installed? if you don`t mind answering?
I mostly repair boilers as thats more technically interesting.
In a typical year I probably install about 8-10 boilers.
Tony
But when I install a boiler I do it properly and calculate the gas supply pipe size first and upgrade it as required!
Its not economic for a British person to install full systems when the Polish do it so cheaply in the big cities.
Tony
Wow, text book answer, from a non installer, i bet you don`t fit oversize combi`s for their hot water flow rate capacities either do you? regardless of heating requirements?
Wow, text book answer, from a non installer, i bet you don`t fit oversize combi`s for their hot water flow rate capacities either do you? regardless of heating requirements?[/quote]
Wow, text book answer, from a non installer, i bet you don`t fit oversize combi`s for their hot water flow rate capacities either do you? regardless of heating requirements?[/quote][/quote]
c'ya :D
A year!!! do that per month.
How many full heating systems, vented /unvented?
8-10 boilers a month? And you still fell for the most basic problem? Who are you really, because this IS a wind up.
20M of 22mm and then into the existing carcass? You need to calculate the existing stuff a sweel as the new. But then you obviously know that, being a man of experience.
Parameters. Yes there are parameters, the meter pressuure can be between 19 & 23mb. Therfore you need to know the
The definition of a troll is "Someone who kicks another poster's ass." :mrgreen:
Working pressure at meter proves governor/regulator. working pressure at appliance proves pipe sizing,sorry i asked, place is full of comedians. :roll:
simple question - did you check the pressure at the meter ?
i have a feeling the answer is no
if you didnt chek the pressure at thte meter ,then how can you tell what the drop across the pipework is??
i cant put it any simpler than that
get your tools out and go back and check the job
Why is everyone feeding the troll?
Mr. W.
was thinking that myself.
i find it sad that people have to rise to it and argue over a internet forum.
it seems it doesn't matter what forum you visit, people like to argue and bicker, because they always have to one up each other.
this will get locked soon anyway..
ok Im gonna have a guess and say, this is the return of Legion? Come on I have to be right? :D :D
I've installed loads of boilers with a drop of 4-5mbar between the meter and appliance, what wrong with that? They still worked.
Status
