H
Hot&Cold
Ah that makes a difference to me,i can only advise on property law down south.I don't believe any one company 'owns' the building. This is in Scotland.
Good luck thou
Good luck thou
You can use plastic waste pipe for the sleeving in the ceiling. Much cheaper.
Use solvent welded waste pipe (glued). No need for super expensive tracpipe.
But then someone else could cut into it thinking it's overflow.
I cut into a Lead gas pipe last week thinking it was water
As already mentioned and for the reasons given that advice is incorrect and dangerous.
where about in Scotland are you ? it is true than England and Wales have slightly differing regs, but they are pretty much the same regarding gas pipes, only really government legislation on Part L , or energy efficiency and some electrical stuff is different.
I bet you shat yourself.
Andy
Alert! One of the thread wreckers is active. Too much time and not enough work for them.Moron.
no you dont, op this is absolute shoite,You put yellow gas tape around the plastic waste pipe and make sure at least one end is not sealed.
Hello,
We've been informed by our building factors that gas pipes under our floor have been fitted incorrectly. They have informed us the 22mm copper pipes have been fitted without supports or coating and are resting on concrete, posing a corrosion risk. This work was done approximately 8-10 years ago when the building was being constructed.
We have been seeking quotes to carry out the necessary repairs and received a lot of conflicted information/advice. One solution that has been proposed is to take the gas pipes (using gastite or tracpipe) into the ceiling void and run it through that to the boiler. This would be run through a duct according to one engineer, quoting regulation BS6891:2015, 8.16. From what I understand, ventilation is the issue with this solution. Can anyone tell me, what ventilation is required in this solution?
To clarify, the ceiling is plasterboard with downlighters in it. We have inspection hatches installed for flue inspection. There is a void above the ceiling plasterboard of around 18-24inches.
