fitz1 said:benchmark would cover new install, but u would need cert for existing appliances and pipework.
Pipework can be tested as new.
All existing appliances would require the safety check as per the regs.
BOB.DOLE said:a) a copy of the record made pursuant to the requirements of paragraph (3)(c) above is given to each existing tenant of premises to which the record relates within 28 days of the date of the check;
and
(b) a copy of the last record made in respect of each appliance or flue is given to any new tenant of premises to which the record relates before that tenant occupies those premises save that, in respect of a tenant whose right to occupy those premises is for a period not exceeding 28 days, a copy of the record may instead be prominently displayed within those premises.
tekkiesteve said:Thanks for your help, just checked corgi site new appliances should be safety checked within 12 months of their installation date.
Steve
tekkiesteve said:Cheers doitall just thought i'd double check no offence but as i said i needed a definative answer.
Thanks again
Steve
Steve
doitall said:Thank you Tony, some of us know that.
Poor old Bob thinks the guy that does the LGSC is a different one that does installation work.
BOB.DOLE said:doitall said:Thank you Tony, some of us know that.
well i find that installation fitters have very poor knowledge of gas regulations, i seem to find a fault on nearly every installlation i come across,
BOB.DOLE said:well i find that installation fitters have very poor knowledge of gas regulations, i seem to find a fault on nearly every installlation i come across,
peter1450 said:Good to see all you fitters agreeing with each other what hope is there for us mere mortals?
