- Joined
- 8 Nov 2021
- Messages
- 9
- Reaction score
- 0
- Country
I currently have a Ferroli 38 HE Optimax Boiler that is 13 years old and would like replace it. My CO2 monitor activated due to low batteries, but it has caused me to reflect on the current boiler which also has a small water leak i have noticed.
I have had a couple of quotes, but during my latest inspection the Gas Safe Installer queried the size of the gas main suggesting the 22mm Supply pipe was insufficient for the current boiler size.
A vast majority on the gas main from the meter to the boiler is inaccessible on the basis it is buried under my extension. The short section either end is 22mm copper, but i am aware that the main pipe routed under the extension is yellow plastic, but I have no idea of the size. My estimation is that the yellow section of pipe is approximately 20 metres in length and would have been upgraded by the previous home owner who installed the boiler.
Ideally, I would like to replace the boiler wfor one with a similar or greater DHW flow rate. The most recent installer suggested that was not possible due to the gas supply main size. None of the other quoters took any measurements of the pipe or asked about lengths or elbows.
I am now left a little confused as where i stand. Is it possible to get a Gas Safe engineer to identify exacty what Size boiler I can install without being able to access the pipe?
It is not an option to replace the main without digging up my extension sub floor, so I will have to pick a boiler that suits my current setup.
The 3 visitors providing quotes all contacted me as a result of a online request from a boiler comparion site, so i have no previous knowledge of their expertise. My current boiler had a replacement fan a few years ago under warranty, but has had no issues concerning levels of gas supply.
