in both of your threads I've seen you changing the goal posts of what you need , say what you want / need at the beginning then people can advise accordingly not changing mind after 3 pages. first just soldering then for brazing , paint stripping and heat shrinking , I'm not having a go just please DECIDE ???
And I'm not changing my mind, or moving goalposts. (Nor did I in the other thread.)
I said, in post #1, that I was interested the availability of different nozzles etc. I then realised that it seemed as though people were assuming that I only meant different sizes for soldering bigger pipes, and I should have clarified then.
I'm sorry if my delay in doing that has caused any confusion.
To repeat what I said, again right at the start, I will
probably never want to use it for anything other than soldering 15/22mm pipe. But who knows - I
might want to do light brazing, I
might want to use it to strip paint, I
might want to use it to burn weeds, I
might want to use it for heat-shrink sleeving. I have no intention of going out and buying a sackload of different nozzles, extension pieces, hoses, regulators etc so that I have all those capabilities lined up and ready to go, but I
might be interested in buying a torch for soldering 15/22mm pipe which had options for different burners so that if, down the road, I wanted to strip paint or burn weeds etc, I could just go out and buy an appropriate fitting then.
