Hi doitall...yes your spot on 100KWHR...which is what i wrote earlier Tony.
Anyway,
You say get the boiler stat down to less than half way, will this encourage my boiler to cycle more even when there is demand for heat?...which is why i have it set high....I assumed the less cycling the better...ie if there is demand for heat burner should be on.??
Whats the general thinking here?
I turned down the boiler stat last night from 5 to ~3 (max is 6)
Which according to MIs means i have reduced the flow temperature from ~77 to 63.
The rads were noticeably cooler this morning but it was particularly cold this morning so ill know later on if they are capable of warming the house @ 63 degrees.
Also this is how i got to 17.9KWhr
.027333(usage per minute)*10.9321(conversion factor on my bills)* 60(minutes per hour) =17.9
Cheers,
Marty.
Anyway,
Cheers,
Marty.
