- Joined
- 14 Jun 2017
- Messages
- 3
- Reaction score
- 0
- Country
Make: Citroen
Model: C3
Engine size/Type: 1.4 Petrol Manual
Year: 2005
Mileage: 107k
So I had just parked the car and wanted to slightly correct my parking by going into reverse. So I pressed the clutch pedal and put the shifter into reverse, then it sounded like something had slipped(Not 100% sure, can't remember the exact moment) and all of a suddenly my gearbox won't work properly. 1st and 2nd gears are virtually impossible to switch to, I'm unable to turn the shifter to the left to engage them. 3rd and 5th gear is very similar. 4th is fine, and reverse too I think.
With extreme force I'm able to partially switch to the broken gears, but it makes a weird 'clicky' sound and it won't stay in that gear (The shifters goes back to the neutral position).
Also if I put into neutral it seems like it is still in one of the gears, because as I lift the clutch pedal up the car goes forward. I was in a very tight space and wasn't able to move forward match to determine what gear it was stuck on. I had taken the plastic cover off, but to a non-technical eye nothing seems wrong, no loose parts and nothing seems to be broken.
Model: C3
Year: 2005
Mileage: 107k
