My parents have had a GEC Nightstor for over 20 years and it has been a good system. Sadly the system was flushed out and after that there was banging from the pipes and it eventually cut out. They paid to have it flushed again and it worked for 11 days then same problem and nothing plumber could do.
Anyway I believe the heat exchanger has been blocked because of the flushing which was exited from a radiator and not the drain in the boiler.
I think if I turn of the valve next to the pump and open the drain in the boiler compartment and flush from the header tank this may clear the heat exchanger. Has anyone done this or had a similar problem.
There are two radiator circuits upstairs and downstairs (under the floor in concrete). I think the water is boiling so the pipes bang and the thermal trips cut off the fan.
The pump is on position 3 and another issue may be the pump is not pumping enough? Thanks to Mike the boilerman for ringing me back and leaving a message - I wish he lived closer!
Thanks for any advice etc
John
John
