D
Doctor Drivel
Thanks Slugbabydotcom & The Baker for the last two posts which seem to address the problem
It looks as if it is a severe blockage below the pump. We drained the system and took off one piece of the pipework today and fushed again but the boiler still locked out after 10 minutes so we didn't get it all. Not much more we can get to without having up the recently fitted carpets and tongued & grooved floorboards!
Looks as if I will have to go with Powerflushing as the problem is mainly in the pipework not the rads and even if we need a new boiler most companies require an old system to be flushed.
I guess there could be quite a lot of muck throughout the whole system and its not the weather for taking off 16 radiators and flushing them in the garden and this would not help clearing debris in the pipework.
Thanks to all who posted.
You could attach the mains to the system and cap off the cold feed and open vent. Then close all rads and open one at a time and open the mains tap. with the drain hose attached. Make sure the flow does go through the rad. This can clear the rad and the pipework along the way. Worth a try.
