I think I'm in the right section.
I have a Clarke PG2500A generator, which has been fine until recently, when the voltage has started dropping out randomly.
The engine runs perfectly but the volt meter drops right down to 30-50v then bounces back up when under no load, and when under load the engine shuts off. It seems to get worse the hotter it gets - but I might be imagining that.
My neighbour - a retired marine electrician - thinks it's the AVR module - is there a way to test it off the machine?
If it needs replacing will any generic AVR do if it has the same specs, or do I need a machine specific one?
Thanks.
Thanks.
