Generator Size
29 Jul 2007
Stirlingshire
We would need to buy a generator to power a house we intend to build in a remote island off Scotland. There will be no electric supply after the house is finished. Therefore, we would need a continuous run gen set to power the house. The electrical content of the house is estimated to be 65,000 WATT, of which 40,000 watt are motor ran units such as air-conditioners.
Could you pls suggest what size and type of generator set we would need.
Regards.
Why on earth do you think you need 40kW of air con? Do you think the islands are hot? And what is the other 25kW for?
You surely aren't thinking of using electricity for cooking, heating or hot water?
Is this the same house as the one you are building in Nigeria?
No gas yet, so yes I am planning to use electric for all.
I may have calculated the air-con power consumption wrongly. Total air-con is 15 units of 18,000 BTU.
The other includes lights, cooker, iron, water pump, etc.
Regards
Regards.
That is a lot of motorised equipment
Firts thought is you are going to be running oil fuelled ( or maybe gas fueled) generator. Have you given any thought to air conditioning using a oil fuelled motor instead of electric. It could be more efficient.
Also have may be have two generators. A small 5 or 10 kilowatt for lighting and small loads and a second larger one powered only when needed.
Yes, John. it almost the same one we are building in Nigeria but this is bigger. As we hope to use it as a B&B
It is very inefficient to use electricity for heating, cooking or hot water. get an oil boiler, and use a gas tank for cooking.
Agree with diesel engine driven compressor which would be more efficient but you are wrong to imagine you need air con on a Scottish island. Woolly vests are more useful.
Do the air con units double as heat pumps? If so I think this is a better idea than electric heating. Certainly less power consumption. :D
It will be more efficient to have 1 or 2 building-wide heat pumps with a bit of redundancy in there in case one breaks down.
Regards
What about using gas bottles, to run the cooker & maybe the water heating.
As the Cookers in my Uncle's pub in NZ, run off of 2 tall red/orange coloured gas bottles, as there is no gas supply in NZ.
