Get the Mole in?
17 Oct 2016
Hello - Will an upgraded water supply mean I get better flow rate through my unvented heating system? A couple of the rads on the end of the system heat up but aren't scorchio. System been cleaned etc. Would the upgraded supply have a positive impact on this or is this more a pressure than flow issue? Anyone done this to good effect? I'd upgrade to 32mm supply moled in from the main.
Cheers all
yeah tried the balancing. never made much difference to be honest but thanks anyway.
The water in your CH system is a closed loop, should only need topping up on rare occasions, or after maintenance. If rads arent heating up you have a restriction somewhere in the system. Nothing to do with the mains supply, you may as well upgrade the compost heap, it'll have as much effect on cold rads.
