B
BigBurner
To those who cannot figure out the obvious merits of using two combis:
I specified a few installations not long ago using two combis. The Pikies were stealing expensive cylinders. No cylinders and combis on jigs with plastic pipes and removed until final commissioning. They work a treat and customers are delighted with them, especially when two people are using two showers - one shower dopes not interfere with the other and they can stay in them for ever and no waiting.
- Two combi's will provide good showers for as long as you want - all day in there with two showers going, if you are that way inclined.
- The two combis release valuable space taken up by cylinders and gives a natural simple zoned heating system saving money on fuel bills.
- No contest, the two combis win hands down, on all points to gain a zoned heating system - one combi on a stat/programmer does upstairs and the other on a stat/programmer does downstairs. Totally independent supplying two floors.
- Two combis guarantees good showers and a bath (combine the outlets for the bath only using two non-return vales and small shock arrestor, and liberating space:
- Low capital cost of installation. Combis are cheap. Two combis gives more and cheaper than a system boiler and unvented cylinder.
- Cheap running costs, upstairs heating can be off most of the day.
- No waiting for showers
- Showers never run out of hot water
- Simple zoned heating system with independent time zones.
- Different rad temperatures on different floors.
- Different room temperature stat settings on two floors
- Less controls to go wrong, with accompanying down time and expense. (no zone valves, complex wiring and the likes)
- Always heat and hot water in the house somewhere. Two combis means built-in redundancy (backup).
- Super quick warm up. Two combis heating a house from cold does it in super quick time.
- Releases valuable house space by eliminating a cylinder and tank.
- One combi can supply the kitchen and the other the utility room - always hot water in the food area.
- Fast bath fills as they only combine DHW outputs to fill baths. Two cheap 10 litres/min combis will deliver 20 litres/min.
- Less wear as the usage is spread between two combis.
- Quick installation.
- Simple installation.
- Simple electrics. A mains point to both and one from each to a stat/programmer on each floor. The stat can be a wireless model for even simpler installation.
- The two combis can be in separate locations or both together, or both out of the way in the loft.
