I know this is a DIY forum, and I love DIY and learning along the way, not to mention the excuses for new tools But, I also try and do things properly, and with electrics, I will get them signed off.
Just curious, how much DIY electricians are happy with if they have to put their name to any part-p or minor works certification?
For instance and simplicity, assume adding sockets to an existing ring in a (non-bathrooom!) room
- Sockets installed correctly in permitted locations
- Cables chased in safe zones and in conduit
- Sockets wired to cables
- Correct size/spec wires
If the final connection to "live" ring are untouched, so electrician can test new cables in isolation, can see the cable runs visibly, and can then make the connection to the existing ring (from existing sockets) - it that usually OK?
Or do electricians insist on running the cables and connecting sockets themselves?
(Just seeing before I speak to local electricians - as if all say you they want to install faceplates, then so be it, but if some are happy with that being done, then I can ask around till I find someone who will! And I know they can probably do it quicker/cheaper, but you don't get the DIY pride effect if that's the case!)
