Socdesign,
Sounds like the second cylinder has done exactly what mine did on the second go round, it was fine for a few weeks before starting to pop.
The popping over several months will start to get worse from my experience and you might get it popping even when no hot water is drawn off.
I've recently installed a new cylinder to replace the second Gledhill because the customer couldn't live with the noise and it wasn't getting resolved with Gledhill.
I installed a Plumb Centre cylinder and so far so good.
I'm trying to get a refund from Gledhill but not sure if successful yet?
We need to make them aware that its not a single case because they are trying to suggest that its an installation fault.
Gledhill made over complicated sludge buckets and now they can't even make a simple unvented cylinder.
It will take a lot more than marketing hype to get them out of this one!
