nickso said:
are you handy with tools/water?
if so a fairly simple temporary solution is at hand. the filling loop valve is probably broken inside. if you shut off the mains water to the house and leave a hot water tap open and remove the loop tap you can push the valve open and refill the boiler until you get a replacement. once you have finished filling you turn it closed as normal.
you will defo need a new loop tap though.
That ties in with my suspicions (does the poorly documented item at the following link look appropriate?
http://www.heatandplumb.com/acatalog/Filling_Loop.html#aHP_2dLOOP1 - linked from previous page on 24cxi;
http://www.heatandplumb.com/acatalog/Glow_Worm_24_CXI_Heat_Pack.html)
Yes, am handy with water and have 3 1970's VWs, so pretty handy with tools
My understanding of the loop (and looking through docs at glowworm site) is that the valve feeds directly from mains, so if I switch off mains and remove valve (just done this, and seems straightforward), how do I get water into the system - or am I required to hijack the garden hose and jam that on in place of the tap once I've jammed it open?
