I wonder if somebody could offer some assistance please. I've recently moved into a house and I'm having a bit of bother with the boiler. It's a bit different to the combi boiler that I'm used to.
The boiler is a a Glow Worm Space Saver 60 MKII and is pretty old. Last night the heating fired up as normal but the radiators stayed cold. I've tried searching a few forums and it sounded like it could be the pump (Grundfos). I've taken the cap off the pump as suggested and the shaft seems to be rotating ok. I tried changing the pump setting from 2 to 3. The radiators were still cold and I heard a noise outside. I went out and saw that the overflow was gushing water. I now know that the overflow is located in the loft but I don't know what else is up there as the opening is a tad small to get through. I'm sure I can squeeze through if someone gives me a good reason to but it won't be pleasant. I've turned the pump setting back down so I'm back to square one. As I said, the boilers old so it doesn't have any flashing error lights or dials which I can report on but it does seem to fire up ok. There isn't a pressure dial so I'm guessing that there must be a tank in the loft? As a side note, none of the radiator thermostats seem to work. The heatings either red hot or off. Cant say I'm overly impressed with the system and I think its going to cost a fortune to run but money doesn't allow a change at the moment.
If anybody has any suggestions that I could try then I'd be very grateful. We have a separate water boiler so hot water isn't an issue.
