This is happened a few times in a few years, but I noticed my boiler pressure was 0.8bar, so I topped it up to 1.1bar turned the heating on and away it goes.
I went outside and noticed the floor was wet and water is slowly dripping from the PRV, I turned the heating off went to the boiler and it’s reading 3.4bar now slowly coming down.
This only seems to happen when I top the boiler up to increase the pressure.
There are no leaks coming from the boiler internally, just through the PRV.
If I let out pressure so it’s around 0.8/0.9 again (back to square one) then it’s fine, but I believe the boiler pressure should be around 1 to 1.5bar normally.
No errors on the boiler even at 0.8 bar, just something I noticed and no errors at 3.4/3.5 either even when there’s a drip from the PRV.
Any ideas what’s up with it?
P.S i’ve turned the CH off now and will check in an hour or so what the pressure reads once it’s cooled down
