Hiya,
A person (not mentioning any names) has put a timer dial onto my glowworm boiler.
Ok, I will try and explain what they did. The wire just came down from the boiler to a flat surfaced socket on the wall underneath. They cut the wire in half, drilled a 4 plug socket onto the wall, then from this socket the wire went into the flat white square on the wall.
The timer dial went into the put up socket drilled to the wall, then another plug comes out of the timer switch up into the boiler.
I have phoned the housing, and they are coming out monday. Am I in trouble for allowing someone to do this?
Your insights needed - what do I tell them on monday the boiler person, as I have been to the corgi website and it is illegal to diy if you are not registered. By my phoning this shows that I am worried about the safety of this.
Hoping you can all help.
Sergiev
Sergiev
