No I mean the usually 15mm pipe feeding water from the F&E tank into the >>>>Do you mean a blocked feed pipe from boiler to pump?
Yes that one!I guess a Myson aerjec is the separator you refer to?
If a magnet sticks to where this feed enters it you know it will be chocka with crud.
Thanks for that Slugbaby, A fairly powerful magnet sticks anywhere on the Aerjec, I guess take it out and fit new is better than trying to clean it out?
What is the reasoning behind that test? Oxides from the rads?
Added later- Magnet also sticks to the pipework in that general area, especially the horizontal runs - More crud?
Added next day-Drained down and took pump head off again, inside all black, I think its made like that. No sign of rust but haven't removed shut off v/vs.
Spent a few hours removing shelves and door of compartment to allow good access for unsoldering air seperator, provided the plumber is happy for me to do so. I know I didn't like putting things back together when someone else had dismantled them.
