Good steel drill bits?.
10 Oct 2017
Hello all, I have 10 holes to drill for m10 tap size in 10mm thick plate.
I beed some decent hss drills!.
Any recommendations please?, are DeWalt any good.
I can sharpen them again so no loss if I have to re sharpen after 3 holes or so.
Cheers Keith.
'Split point' cobalt bits would be my recommendation. Presto or anything from Sheffield are probably the best but the price will make you weep.
So, nowadays, I just go for anything made in Germany, usually Heller. I drilled many holes in 10mm mild steel with a new bit, although I was only tapping for M6, i.e. a 5mm bit. Downside - split point bits can't be resharpened manually and maintain the 'split point', they just become 'normal' bits after that, but still very good if they are cobalt.
