Can I interchange the head with another make, don't want to drain down to replace... I've already replaced the motor on this valve so I think it's time to change.
I can get Honeywell, Drayton, Siemens...
Thanks..
Potterton made a similar valve but that was unreliable.(I think it was a myson rebadged) Best advice.........fit a Honeywell complete valve. I know you said you are trying to avoid a drain down but it only requires draining to just below the valve and not a complete drain.
