Hi All ,
My first post so please be gentle!.
I have a Grant Combi mkII which has been giving me an over heating problem after using hot water recently , prime example is i have a shower in the morning before work hot water is fine , by the time i've dressed and come down stairs the boiler has gone in to 'Overheat' , eventually once the boiler has cooled i can use the reset and the boiler will work fine , this does not happen every time the hot water is used.
This has been happening for few weeks now and on the advice of 'a mate' i changed the expansion vessil which i thought had cured it as it had not over heated until this morning when it did it again after i had a shower.
Any suggestions please?? - i'm thinking either partially blocked heat exchanger or faulty overheat stat maybe ??
Thanks.
Thanks.
