Sounds like a large inductive loads frying the contacts closed, or a fault somewhere causing a fault current which is frying the contacts together (you would then get a blown fuse or trip gone).
We have been told that the lights now do not go on and off even if the dial is rotated through 24h manually. It seems that either the contacts of the timer (3 timers!) are not working (faulty or welded) or there is something fundamentally wrong with the wiring.Does the timer keep to the correct time ? Or does it stop turning at some time ? Maybe the supply to the motor has been wired to the switched output instead of the permanent mains supply.
Do you mean that everything is now working 'as intended'? I presume you didn't 'do anything' to result in a change?Timer is working
That's certainly not enough to do any harm to the timer.There are seven outside lights ... 2 led brick lights which I have just had put in to replace the old ones as I thought they may be leaking but the problem was there before 5 energy saving screw fitting bulbs I think they are 11 and what I call curly to look at
OK - I misunderstood.No sorry ... I was asked in previous post if the timer was working as in keeping the correct time ... It was a reply to that.the timer is functioning as a clock but does not switch on and off
With such a relatively small load (and the lights all working), I find it very hard to believe that the contacts could have got welded in one timer, let alone three.I did ask if the timer is"welded" is it permanently damaged and is there a way i can find out if this has happened
