I wanted to hear if there are many systems out there that reverse the normal 'Mains cold + Stored Hot' pattern.
In this house I'm thinking of combining a mains fed 40kw Vaillant 937 storage combi with a gravity cold water system from 200 gallon loft tank.
The Tank will fill quite slowly leaving the boiler most of the mains feed - ensuring the powerful boiler has sufficient mains cold water supply at all times of the day (neighborhood mains pressure varies a bit). If the the tank (ever) gets half-empty a second full-speed rate stopcock activates.
Is this unique?
Given that the reason for this system design is to ensure the combi can deliver on its promise to supply sufficient hot water flow to several showers simultaneously a second question is
...with 5 ensuite showers proposed - should the system use a single thermostatic and pressure balancing shower valve in the loft - and allow this to distribute premixed shower water to simple shower heads in each ensuite via dedicated pipework - rather than buy 5 separate thermostic bar valves or something (which might struggle with the pressure balancing anyway)?
Is this unique?
