Ok, just had a boiler guy round earlier to test water pressure and flow.
The results are in....
....drum roll please....
....6 bar pressure and 24lpm water flow.
So looks like mains upgrade not required.
At 6 bar static its unlikely you won't be achieving 20l /min @ 1 bar dynamic. I have 7 bar static in my home and 20l /min @1.2 bar dynamic.
All piped in 15mm copper.
Static pressure is not irrelevant when its high pressure. Unless the property had seriously convoluted pipe runs or blockages.
I did my brothers loft conversion a few years ago. Just ran a 15mm mains supply and electric shower and ariston water heater for the basin. Job done.
Changing it over to an unvented cylinder would have been at least 3 times the cost. And you have the issue of the old pipework not withstanding the pressure, an installation nightmare with the discharge pipe plus a yearly service.
It also ruled out the need for a secondary return circuit as it was a long run.
I've heard of a unit that bolts to the side of the cylinder which incorporates a plate heat exchanger and uses the energy in the existing vented cylinder to provide mains hot water to the taps.
I've never seen any merchant stock it though or seen one in action.
Availability issues will probably make it prohibitively expensive.
