- Joined
- 27 Jan 2008
- Messages
- 24,927
- Reaction score
- 2,884
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We see again and again on this forum central heating wires up with the green and yellow wire over marked and used for some thing else other than earth.
We all know an earth is required for all installed wiring other than a pendent from the ceiling rose, so no question we know it is wrong and does not comply, however we see it so often on these pages just seen another here I was about to say it was not allowed, then stopped myself as it would likely serve no purpose and just worry the poster.
So should we bother telling people or not, and is there some thing they can do about it? I really don't believe all these thermostats have been DIY wired, the Persimmon home my daughter once had was clearly wired by either Persimmon or a contractor to Persimmon not the house owner and there was no neutral fed to the thermostat, as a result there was a large hysteresis, and I can understand why some one would use the earth wire as a neutral to reduce the hysteresis, however in theory Persimmon were breaking no rules missing out the neutral.
Central heating installers do tend to want the service work, and often put stickers on the boiler saying who they were, and we have been getting more and more EICR done, if lack of an earth is missed, could the home owner ask the inspector to foot the bill when the installer is no longer available, assuming he would have been at time of inspection.
OK missing earth likely does not mean potential danger and the inspector may not consider worth correcting, so maybe not even a C3, but should it be listed? We have got rid of code 4, so maybe it shouldn't?
For wireless thermostats I only know of one receiver that does not need a neutral, the Nest e, not seen any others, so should we point it out, as it has been with this post or shrug our shoulders and say nothing.
The same with 12 volt down lights converted to 230 volt, so often no earth to the lamp. And with both thermostats and down lighters often nothing to connect an earth to even if it was there.
