Hello
I am a new member and spent 30 mins trying to find a forum that seemed to be looking at the New Green Technologies so I definitely think a Green Forum would be a great idea.
Calling it Green Forum would certainly open up a lot of cross over discussions so naming it New Green Technologies would weed out a lot of unwanted stuff (but not all).
I have had installed in my house one of these new (although the technology has been around for some time, its just beginning to be seriously looked at) Thermodynamic Panels.
The firm that installed it call it a solar Thermodynamic panel (by no stretch of the imagination can it be classed as solar, yes it will use solar power if available but it works best when it is raining and dark.
It is closer related to a Air source heat pump although an air source pump utilises a fan to push/pull the air over a heat exchanger filled with a form of low temperature fluid.
The Thermodynamic can best be described as a fridge in reverse (it pulls in any temperature over -5 degrees and below 40 degrees placing it into a refrigerant) it is then sent into a heat exchanger where it dumps the extra temperature (could be 1 degree or 5 degrees) into your hot water it then returns to the panel via a compressor to repeat the process.
I may have the circuit the wrong way around but it definitely works (I live in Scotland and the weather we have been having over the last four/five months has been freezing, the highest temp has been 4 degrees.
The system was installed in November and the cylinder temperature has averaged 53 degrees, My wife used all the hot water one night so it was down at 14 degrees but the following morning it was up at 48 degrees, (the outside temperature was 0 degrees and it was raining. Several hours it was back up at 55 degrees.
It may not be free hotwater but for the cost of maybe 1 or 2p a day it sure comes close.
And I AM NOT A SALESMAN just an very interested party it seems as this is fairly new technology (in Building terms) a person might not know much about it and are very cautious regarding it, or they think they know all about it and see the term it 'Free Hot water' so condemn it as a gimmick.
Scotsplum
