D
Deleted member 317777
Can I see that article please ?I've just remembered something I read last year. Apparently, you could easily fix the winter problem just by fitting a bigger ASHP. But then it wouldn't run efficiently in the warmer months. There is a sweet spot for efficiency of about 50% output, IIRC.
I’ll use my house as a quick example. It’s got a 14kw heat loss, I’ve range rated the boiler to 18kw.
When it’s cold I can’t achieve the desired room temp unless I set the flow temp to 70 degrees.
That should highlight the real issue
