Greenstar 28i Junior FAN replacement
Status
Not open for further replies.
10 Jul 2018
Hi All, We have 28i Junior that shows now error lights, when powerd on at the mains the fan spins for about 15-20 seconds, then stops, the blue light is stable and no other lights flash etc, the fan the runs for out 1/2 second and continues to do this, a engineer diagnosed the fan as being faulty, he sad the whole unit needs replacing and the fan was s sealed unit and the speed controller could not be replaced, and that the top of the combustion chamber will need to be removed to replace the fan.
I have searched the forum and google , youtube etc , I know the motor PCB is available:
https://www.nationalboilerparts.co....530-87161160670-replacement-fan-pcb-only-new/
does the combustion need dismantling to replace the fan?
Thanks in advance
Gaz
Moderator's note:
If you are asking to verify what you have been told, that is permissible.
However if you ask for advice on how to do it yourself, the forum will not encourage you.
See https://www.diynot.com/diy/threads/diy-gas.8090/
Yes it needs to be removed still, very much a gas safe registered job.
[QUOTE="
Moderator's note:
The forum cannot help you on anything you might do with gas.
[/QUOTE]
Thank you for the clarification on forum rules, I just wanted to confirm the the information I was given was correct, I was told the fan was a 'sealed' unit and the fan speed controller was not replaceable, 2 minutes on Google shows otherwise, happy to pay for a registered engineer to do the work.
Don't believe everything you see on the internet, call the boiler manufacturer or a GSR.
Status
