No noises from the fan or pump, dead as hectorAny noises from fan or pump
The fuses have been checked and are ok so that rules them out. There is 240v at the boiler connection so the 3 amp fuse at the spur has to be ok.Fuse pcb or spur. That’s where I’d be starting.
Ok thanks I'll tell the engineer to order another new main PCB board and see if that does the trickYou’ve answered the question yourself. Start there
How did you manage that then ? Oops sorry how did your engineer manage to test the correct voltage on a disconnected transformer ?The plug in transformer on the PCB board has been tested remotely and is giving the correct voltage outputs.
I didn't do the test but he said the readings were fineWhat was the resistances
It's a black transformer and there is 1 blow and 2 glass fuses.Is it the blue or black transformer. How many fuses are on the board
Was told it was giving out 9.5 volts and 24 volts.Resistances on transformer
